Forum Home » Sound Reinforcement » LAB Subwoofer » Lab sub questions (impedance & using 1 per side)
| Lab sub questions (impedance & using 1 per side) [message #319373] |
Sun, 04 May 2008 15:02  |
Matt F Castle Messages: 6 Registered: April 2008 Location: Nr Cambridge, UK |
Hi,
I’m looking on embarking on building a pair of Labsub’s and have a few questions before I start:
How will 2 Labsub’s (1 per side) perform, as I read there designed to work in groups of 3 or 4? Will running them singly have and detrimental effects on there performance or sound?
The idea will be to build another pair in the future for 2 a side or a single block of 4 but until that point it will be just the one each side in most cases, so I’m after opinions if it’s worth it or for that number if I would be better off looking at other options?
What impedance will an amp see from one box? Current power option is a QSC PLX3402 (which I’m hoping should be plenty??), looking at one of the poll’s this is quite a popular choice.
Are there different wiring options to get the impedance of a Labsub to close to 2ohm’s (I’m assuming from what I’ve read 2 lab12’s in parallel would give 1.5ohm + the horn loading and end up been nearer 2ohm+ or will that cause problems with to low an impedance on the amp?
Also roughly what sensitivity are the Labsubs (40 - 90hz)
Cheers
m
| Re: Lab sub questions (impedance & using 1 per side) [message #319383 is a reply to message #319373 ] |
Sun, 04 May 2008 16:16   |
Al Limberg Messages: 1197 Registered: April 2004 Location: Saginaw, MI |
Read again oh young one. The Lab12 is a 6 ohm driver, which, ignoring the acoustical impedance of the cab, would result in a 3 ohm load for a pair of 12s in parallel. I run four cabs (4 Lab12s per side) off a QSC RMX5050 with great results, certainly no heat problems or early onset of clipping. Another poster in a previous thread is running his Labs from a Crown with the onboard computer which flickers between 5 and 6 ohms with a single LabSub per channel. AS far as running a single per side, I have been more than happy with the results. Admittedly they are a bit large to haul in such a circumstance but the performance is fine. I typically hi pass singles at 35-38Hz and a group of 4 at 32Hz. I can't quote you specific sensitivity figures although the early Danley posts as the LAb was developed should include some useful info in that regard. I find that while I run a single pair or even a single cab probably 5 times for each time I get to open up four at once, it is worth it to me for those few times. AS a matter of fact, two more will be put in service this summer for a single large festival and to give my son his own pair.
HTH,
Al
Some people are like a Slinky.....not really good for anything, but you still can't help but smile when you see one tumble down the stairs.
| Re: Lab sub questions (impedance & using 1 per side) [message #319499 is a reply to message #319403 ] |
Sun, 04 May 2008 21:46   |
I can't imagine bridging a 3402 into a single Lab. Afterall. that's roughly 3400w @4 amd 2200w @8 - figuring the Lab @ 6 puts your roughly halfway between. That's some serious headroom for a 600w noise/1200 program cab. On the other hand, bridging into a pair puts you at 3 ohms and that is pretty close to the danger zone I'm sure. I typically run mine upright when used singly to get better height on my top boxes but I have on occasion had them on their sides with two tops as you mentio nad it makes a very solid base.
As far as moving them, I'm and old fart with a bit of a heart condition but that's why we have hand trucks. The 13" wheel versions from Harbor Freight move them around nicely for under $40.
Al
| Re: Lab sub questions (impedance & using 1 per side) [message #319525 is a reply to message #319499 ] |
Sun, 04 May 2008 23:02   |
Chris Gruber Messages: 22 Registered: March 2008 |
Here Often |
On the same topic would a Crown CE4000 with 1200w/ch at 4 be a good match for 1 LAB per side?
[Updated on: Sun, 04 May 2008 23:02] -Chris
Uber Audio
| Re: Lab sub questions (impedance & using 1 per side) [message #319591 is a reply to message #319560 ] |
Mon, 05 May 2008 09:13   |
Yikes! Its been so long since I really even considered the power specs,etc. that I may be off with my 300 per driver. The 5050 is like having a big 60's V-8 under your foot. You just press the pedal and it goes (we'll ignore the fuel economy ramifications in this story!) Prior to adding the 5050 to my racks I used a pair of Yamaha H7000s rated at 750 @8 snd 950 @4. On the single pair days I could go with 1 amp for the pair or my Labs are wired for the option of using one driver per amp channel. In either case, tickling the clip LEDs was a rarity.
In regards to Chris's question, I would think the CE4000 would do fine on Labs. You might do a search though as it seems to me, and this is a hazy memory, that the specs on the 4000 are quite different depending on the supply voltage, 110 vs. 220.
HTH,
Al
[Updated on: Mon, 05 May 2008 09:15] Some people are like a Slinky.....not really good for anything, but you still can't help but smile when you see one tumble down the stairs.
| Re: Lab sub questions (impedance & using 1 per side) [message #320660 is a reply to message #319373 ] |
Wed, 07 May 2008 19:02   |
Silas Pradetto Messages: 133 Registered: February 2006 Location: CT |
One per side is almost not worth bothering with. I have corner-loaded a single unit inside and with EQ it is OK. Even 2 coupled is not recommended.
A single LAB sub enclosure is about 6 to 7 ohms according to my Itech 8000.
I run the I-tech 8000 stereo with 2 LABS per side, which is 2000 watts per LAB. I can hit clip limit with no issues and no blown drivers yet.
A LAB12 woofer is 400RMS, 800 "music program". That is in free-air. Once it's horn loaded it can handle significantly more without any issue, since there is much more cone control behind a horn.
Most LAB failures are heat related from too much power over a long time. Mine never even get warm.
My LAB subs can keep up nicely with my TFR mains with about the same power, my mains having a LF sensitivity of 108. LAB subs in a stack of 2 are probably around that.
Synopsis: 1 LAB sub is about 6 ohms, 2000 watts, can't be used single except in special circumstances with EQ, and not at full power. A PLX3402 won't be enough to fully realize the power except bridged into a pair.
[Updated on: Wed, 07 May 2008 19:10] Silas Pradetto
Concerts Unlimited LLC
(860) 377-4020
silas@concertsunlimited.com
http://concertsunlimited.com
Dealer for, well, essentially everything sound.
| Re: Lab sub questions (impedance & using 1 per side) [message #321614 is a reply to message #320660 ] |
Sun, 11 May 2008 03:58   |
Thanks for the reply Silas,
Could you expand a little on what you've said and qualify why one per side is not worth bothering with and why 2 per side is not recommended? What are the "special circumstances" 1 pair (L/R) would be ok?
Al's posts above seem to indicate that they would perform ok in my application.
My back ground to my asking these questions: I'm looking at 1 pair initially (2 boxes, mainly for use, one left one right, the regular gig the PA is on the front of the stage so a centre cluster wouldn't work) as that’s as far as I can make the money stretch at the moment and then be looking at a second pair in the future for 2 per side (or one block of 4).
What I am trying to find out is will one per side work or not until I've got more. Also interested in info about 2 boxes per side if you don't think they will work ether?
The application is mainly live bands and some "disco" music in-between sort of thing so a lack of ultra low sub isn't initially a problem provided they have reasonable performance (with a bit of EQ) in ~3 or 400 capacity room. Also my mid/hi boxes aren’t top of the range so not ultra loud, but the current 4 x single 18" subs can't keep up with them...
How low does the horn load the drivers when used singly?
On the amp front, I've ether got a PLX3402 or a Camco that can do 1600@4ohm/ch. Al's also indicated there should be a fair performance with this amount of power, based on my application so long as they will do the job, also added with been used individually and needing some EQ to get the performance is that not a good thing not throwing bucket loads of power at them? Bigger amps would be a upgrade further down the line when there’s more boxes to power...
Any input is appreciated, been a self build and not been able to hear them first before outlaying the money on them.
Cheers
m
| Re: Lab sub questions (impedance & using 1 per side) [message #321912 is a reply to message #321614 ] |
Mon, 12 May 2008 03:14   |
Walt de Jong Messages: 125 Registered: August 2004 |
If you are using one LAB on each side this probably means the venue is not very big.
In smaller values 2x18" reflex bins ussualy give better results, they are easier to set up, have less interaction with the room and so on. They seem to have more bass up close.
In larger venues, or outdoors, where you really needs lots of acoustic power, the LAB-horns will have the advantage.
Best regards,
Walt
| Re: Lab sub questions (impedance & using 1 per side) [message #322185 is a reply to message #321989 ] |
Mon, 12 May 2008 21:43  |
Gary Perrett Messages: 123 Registered: June 2004 Location: northern minnesota |
It seems to me to be a question of "if your serious" about low end performance. If you are, then get the power, and build the numbers... since 4 is awesome', 6 is 'serious', and 8 is "devastating"! When I first built a (l) LABsub, I laid it down behind the car (outside) and hooked the system to it. It is a "competition" system meant to be run @ SUPER LOW impedance...for LF reproduction power...even @ the LABsub's impedance for one cab it was clearly "thumping" 2 blocks away and could be "felt" 4 blocks away... off response".( I soon added a second and it was...well we HAD to have 2 more...and so on. We have used 6 outdoors(mono block), with "canned" music for an outdoor "pro" lazer light show, it was palpable...you could feel the thump that far away. Note: it seems implausible, but that was all done with a single "Digam" 5000 amp... a one rack space 17 lb amp...That was (by the way) outdoor, all day and night, and it was HOT... That amp even ran on a 150' 16 gage extension cord. Granted not to full potential, and not that day, but it also seemed to work no matter what the speaker... but I digress...
The LABsub's in the configuration they were designed for, finally gave me the low end I had been dreaming of. I have a system in my house and car, and I too wanted to match the impact of the home, and car systems. ( the home system incorporates a "Sunfire" truesub, and Infinity RS1's. I think now... my "house(BAR INSTALL)" system, sounds BETTER than both my "everyday" systems.
Proper numbers, sufficient power, good Edison supply... and you will FEEL the difference... ( Oh and DSP processing like the Driverack 260-4800, or other Pro processor) and it's ADDICTING!
Gary
Twilite Zone Productions
We the few who have done so much, for so long, with so little, now feel we can do everything with nothing...
Current Time: Fri May 16 12:04:53 CDT 2008
Total time taken to generate the page: 3.54100 seconds |
