| How do you transport your Versarray tops? [message #298957] |
Sun, 02 March 2008 09:23  |
John Moore Messages: 61 Registered: March 2006 Location: Tracy, CA |
Wondering if anyone has come up with a way to transport Vray top boxes with a cart or rolling base, or something without going to full blown cases and breaking the bank. How are you stacking and loading in truck or trailer too? I have some ideas but don't want to re-invent the wheel if someone has something that works good and is not too costly. (pictures would be great too)
Always in upgrade mode, I hate that...
Trinity Productions
http://www.trinityprosound.com
| Re: How do you transport your Versarray tops? [message #298998 is a reply to message #298957 ] |
Sun, 02 March 2008 13:15   |
Riley Casey Messages: 502 Registered: April 2004 Location: WDC, center of the known ... |
Our JBL VRX932s travel on 22.5 x 30 dolly sets stacked two high. Very handy truck pack plus finding storage for the emptys is a snap. We have a dozen loose dollys as well as those dedicated to the VRX and SRX speakers with sandwich boards and straps so that just about any collection of small cases can become a standard pack. Very flexible system - just be sure to secure them at the show. They become popular items with bands and other crews. We stain ours brown wood grain and router our logo into the wood to make them a bit more obvious.
| Re: How do you transport your Versarray tops? [message #298999 is a reply to message #298998 ] |
Sun, 02 March 2008 13:18   |
The soft covers are a big part of the trick. The added labor time in dealing with the straps and the covers is more than made up by the labor savings in finding case storage and moving deads to the storage space. We don't do many shows where the empties can simply be piled back stage.
Attachment: vrx dolly.jpg
(Size: 198.57KB, Downloaded 460 time(s))
| Re: How do you transport your Versarray tops? [message #299026 is a reply to message #299017 ] |
Sun, 02 March 2008 15:10   |
http://www.cloud9covers.com/
In addition to our logo we make a point of having our covers be something other than black. They are less likely to get lost in dark corners where they so often seem to wind up even when we make a point of stowing them in empty feeder and motor cases during set up.
[Updated on: Sun, 02 March 2008 15:14]
| Re: How do you transport your Versarray tops? [message #299460 is a reply to message #299300 ] |
Mon, 03 March 2008 21:12   |
Don Lanier Messages: 135 Registered: April 2004 Location: Godfrey, I |
no pics, its a enclosed caster board that the VR 112's slide down into and the top flybar is left exposed, 3 cabinets per side, facing each other. There covered on all sides and protected from bumps and bashes. Black paint, Colson casters, Birch plywood...Lined with Black tuff cloth to prevent scuffs and marks while loading. The top is left open so as you attach the fly bar and lift out three, you then slide the bottom three under insert pins and lift the rest out, Putting them back is the same, simply insert your pins into the top frame for storage.
Don Lanier
Pearl Productions
http://www.pearlproaudio.com
| Re: How do you transport your Versarray tops? [message #321880 is a reply to message #299460 ] |
Sun, 11 May 2008 21:00   |
Finally came up with a cart for our PV Versarrays that works for us...if anyone is interested pics are here...
http://www.trinityprosound.com/speakertransport.htm
Simple yet effective...the cardboard edge protectors are from U-Line for protecting pallet corners...they work well...
[Updated on: Sun, 11 May 2008 21:42] Always in upgrade mode, I hate that...
Trinity Productions
| Re: How do you transport your Versarray tops? [message #321887 is a reply to message #321880 ] |
Sun, 11 May 2008 21:20   |
| John Moore wrote on Sun, 11 May 2008 22:00 | Finally came up with a cart for our PV Versarrays that works for us...if anyone is interested pics are here...
Simpe yet effective...the cardboard edge protectors are from U-Line for protecting pallet corners...they work well...
| Very interesting.
How stable are they with one side empty?
Philip LaDue
RFL
| Re: How do you transport your Versarray tops? [message #321889 is a reply to message #321887 ] |
Sun, 11 May 2008 21:40   |
Pretty good, considering the large base and casters. The only issue is we wish the casters had brakes on them, but had to go with these from ebay since they were found at a great deal. If we are only using one set of 3, the other set just gets secured to the cart and put back in the truck...the carpeting protects the cabinets well. I sometime push them and then hop on and ride to the destination if we have enough room and concrete...they go thru grass ok, due to the large wheels...
[Updated on: Sun, 11 May 2008 21:41] Always in upgrade mode, I hate that...
Trinity Productions
| Re: How do you transport your Versarray tops? [message #321996 is a reply to message #321880 ] |
Mon, 12 May 2008 11:39   |
ThomasDameron Messages: 218 Registered: April 2004 Location: Raleigh, NC... sometimes |
Oh no, it's got dummy wheels on the back. Say it ain't so. Good looking design otherwise.
Maybe you can find a way to thread the straps through the corner protectors so they don't get lost.... oh, now I see the safety cable keeping it captive. Good one.
The only other thing I'd add is a way to strap one stack of three in and leave it connected, then have a separate strap for the other side. It may be that way, it's hard for me to tell from the pictures, but the same cup tie off that you use at the bottom could also be used at the top.
thomas d.
[Updated on: Mon, 12 May 2008 11:40]
