| Re: what are these and where do i get them?? *Editted* [message #319553 is a reply to message #318099 ] |
Mon, 05 May 2008 03:06   |
neil juneja Messages: 9 Registered: September 2007 Location: seattle |
Those aren't just standard scanners, they're technobeams. Still a very competitive fixture, imo. And damn reliable and durable. Will require less maintenance than any martin ever built and amDJ, chauvet, etc can't even compare as far as build quality.
www.SakuCollins.com
| Available Oxygen [message #321289 is a reply to message #321269 ] |
Fri, 09 May 2008 16:42   |
Mac Kerr Messages: 5817 Registered: April 2004 Location: Westchester County, NY |
| jeffhtg (Jeff Kenney) wrote on Fri, 09 May 2008 16:08 | there used to be a couple companies that made a non-moving solinoid based nozzle for co2 and nitrogen.. nitrogen does NOT replace the air we breath - and therefore is much safer in some smaller nightclubs.
| How can CO2 replace the air, but not nitrogen? They are both gases that are filling the space, and changing the oxygen to inert gas ratio. They both entail the same dangers in a small environment. Neither is poisonous, but both decrease the amount of available oxygen.
Mac
[Updated on: Fri, 09 May 2008 16:43]
| Re: Available Oxygen [message #321307 is a reply to message #321300 ] |
Fri, 09 May 2008 17:54   |
Tom Weber Messages: 55 Registered: February 2008 Location: NY |
Maybe the poster was thinking of Carbon Monoxide (where nitrogen would be safer... but not necessarily safe)? Any gas introduced into an enclosed space will have the potential to be deadly. Adding a non-toxic inert gas will reduce the fraction of oxygen in the air, and thus decrease the partial pressure of oxygen in each breath. Addition of large amounts of oxygen could potentially lead to Oxygen toxicity (http://en.wikipedia.org/wiki/Oxygen_toxicity). Basically, if the space is small, be careful how much gas (other than air) you pump into the space.
Thomas Weber
Cornell Productions
Production Manager
http://www.activities.cornell.edu/cp
