Welcome to the ProSoundWeb sound reinforcement forums, home of more than 50,000 audio professionals. Important Notice: Full Names are required to post in these forums; please put your full name in the alias field in your profile.
Brad Weber Messages: 1158 Registered: December 2005 Location: Marietta, GA
Has No Life
You know Bose used the direct/reflected concept for some of their speakers, maybe this is just the larger scale version of that!Brad Weber
muse Audio Video
Ivan Beaver Messages: 4189 Registered: January 2005 Location: Atlanta Ga area
Has No Life
ALl the other loudspeakers were facing the people. It is in a speech-special effects playback type situation. No reverb added.
It is an interesting thought, to achieve a more "diffuse" reverb sound, but I think that line of thinking would be well above the above system design. Can I have some more talent in the monitors--PLEASE?
Craig Hauber Messages: 234 Registered: December 2004 Location: Simi Valley California
Has No Life
Was it near a bar, POS terminal hostess station or phone? Many times the crew will turn around or block off offending speakers that interfere with their daily (already annoying enough) job. Especially if its the same playlist over-and-over!
Craig Hauber
CSA Productions Inc.
Simi Valley & Burbank CA
www.csaproductionsinc.com
Jeff Babcock Messages: 853 Registered: September 2006 Location: Ontario, Canada
Has No Life
I just saw a similar "install" where some EV SXA250's were put in a small 100 cap room with about a 15' ceiling, each box placed almost at the ceiling, with NO downward angle whatsoever. 4 boxes in opposing corners of the room just firing sound at each other instead of the patrons. To say it sounded rubbish is an understatement.
At least in Ivan's case it wasn't the entire system hung like that.....
