| Re: getting rock sound from a clean system [message #160738 is a reply to message #160731 ] |
Sun, 05 November 2006 12:50   |
Randy Gartner Messages: 373 Registered: March 2005 Location: Pennsylvania |
Hopefully,I understand your question. I'll give it a shot.
That grunge,distortion that you are talking about should not be produced by your PA, but by the guitars onstage and brought into the mix by you. Most hard rock and heavey metal music is punctuated by a "big" drum sound,so proper micing,gates,compression and effects can help you get what you want there.These acts also tend to use alot of effects on the vocals. But the key to getting everything to come together, and give you the sound you want(at a volume that is acceptable to the the venue ), is to make sure the stage volume is under control. If the guitars or bass are too loud on stage,you will end up with a mix that's not balanced or, you will have unacceptable volume levels because you are trying to bring everything else up to match them.It can easily get out of control.
| Re: getting rock sound from a clean system [message #160749 is a reply to message #160731 ] |
Sun, 05 November 2006 14:11   |
Hey Rich,
I have a friend who is very analogue friendly and doesnt like how 'clean' my 01v96 sounds. I played around with inserting the equaliser 601 from the channel strip package on the main outs and it definitely introduced some harmonic distortion that analogue friendly people might find more pleasing to their ears.
You can play around with it yourself as if you hold the effect button down as you turn the console on (as long as its the latest firmware version) you get 10 minutes use.
Try it out, see if you like it ... I prefer it clean myself!
Simon
| Re: getting rock sound from a clean system [message #160905 is a reply to message #160731 ] |
Mon, 06 November 2006 07:00  |
Not to state the obvious...........
Rock sound input = rock sound output
As simple as GIGO (garbage in - garbage out)
Best of Days
Never underestimate the danger of stupid people in powerful positions.
Knowledge is the information acquired while searching for an answer, not the answer itself.
Alex S
